I have a problem and looking for advise on how to fix it.
I have had a conservatory built and the walls have been plastered and skimmed. I asked advise on what i should do with regards to painting as i had never painted a freshly plastered wall.
a mix of 50/50 emulsion / water was recommended.
I have done this...the second coat i just used the emulsion as it was quite watery any how...and i have now painted two more coats of my chosen colour in matt.
i allowed plaster to dry for 5 days...and painted each coat 24hrs after each other.
I noticed after my first coat of matt that there where cracks showing in the paint ( honeycombe/ criss crossing effect )..which is highlited more with with the second coat.
I have since noticed my error in that i used "silk vynil" emulsion as the original coating...but i was none the wiser, i wasnt told otherwise. and have now seen info on the net about not painting matt onto silk.
how can i fix this?
do i need to rub down my matt coats until i see the original colour and thus doing so take off the sheene of the silk vynil and paint again?
do i need to remove "all" paint back to plaster and start from scratch using matt ?
can i rub the coats down and apply PVA ( mixed correctly ) then resume painting with matt?
can the paint be washed off to help protect the plaster?
many thanks.
how can i fix this?
many thanks.
