Just lost the use of rad. cooling fan on my mk6 escort ghia 16v zetec, causing the engine to overheat.
Does anyone know how to test or bypass the temperature switch at the source?
When disconnected from the switch, The loom end has 4 wires. The terminals are marked 1 to 5 with no connection to terminal 2.
If i bridge the switch at this point, surely this will activate the fan?
Not sure how to discover which of the connections will allow the fan to operate.
Note: If I disconnect the switch - the fan does not operate either, not sure if it should anyway.
