Euro 76 setup query
30 Jul 2026
I have a Euro 76 alarm installed, the installer has done their standard installation, which is totally fine but I want to know if it can be customised to the way I would like the system to work. Can any of you with experience of this alarm, help me out please? I have a keypad downstairs and upstairs. A few of things I would like to do:
1. Can keypad volume be turned down? Not completely off but down enough where people sleeping upstairs won't hear the keypad when it is being pressed on the landing upstairs at night time.
2. On an old alarm system I had, on the keypad upstairs at night I would have pressed set and then b to set the alarm, without having to put the code in, can this also be done on this panel?
3. Also on the old alarm I had, an indicator on the screen would have let you know the alarm was set, this would have been visible at all times when the alarm was set, is that possible for our upstairs keypad? So people know the alarm is set.
4. We have no internal sounder/buzzer installed, can the volume of the keypads be maximised in the the event of the alarm going off?
I know that any changes will probably need to be done by the installer but I would just like to know if the above is possible before I call him out.
Many thanks
1. .yes…..or set silent part set
2 ..yes…enable simple set
3…yes…area button would be lit ….depending on programming/ grade setting ..
4…the keypads are not very loud so fit speaker / sounder …….which leads to issue 1 ?
