Euro Cylinder Removal
Discussion in 'General DIY' started by cpjvej2014, 23 Nov 2015.
  1. cpjvej2014
    cpjvej2014
    30 Jan 2014
    80
    Thanks Received:
    Hull
    Country:
    Hi all,
    Just moved into a new property with attached garage. Garage has main up & over door. Lock made by "Horrman", need to replace cylinder but don't have the key .. also same goes for the Door into the garage. No keys for euro lock on that Either. Door to garage has euro cylinder, but its not multipoint locking mech its not even a lift handle its just a turn key lock. Handles also don't have screw holes by the looks so cant remove handles. I've removed retaining screw but lock wont budge - more than likely because I cant line up the Cam to remove the lock.
    Any Idea how I can remove both locks ?
    Thanks in advance
  2. foxhole
    foxhole
    14 Mar 2006
    18,220
    Thanks Received:
    2,091
    Kent
    Country:
    You may have to drill the euro if no key available, cam has to align for removal. [assume it's keyed from both sides]
  3. Sponsored Links
  4. cpjvej2014
    cpjvej2014
    30 Jan 2014
    80
    Thanks Received:
    Hull
    Country:
    Yeah it is, Ive no way of getting the Handles off either. Ive got a pic which I will post up.
  5. cpjvej2014
    cpjvej2014
    30 Jan 2014
    80
    Thanks Received:
    Hull
    Country:
  6. Sponsored Links
  7. AdrianUK
    AdrianUK
    22 Sep 2009
    623
    Thanks Received:
    92
    Nottinghamshire
    Country:
    Google "euro lock snapping"..............
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
