- Joined
- 27 Jul 2013
- Messages
- 1
- Reaction score
- 0
- Country
hi i was wondering if anybody could help i am a ftb looking at buying a 1900 semi detached property. it is run down and needs alot of work ie windows kitchen bathroom, decorating,roof repairs etc. i had a homebuyers survey which brought up lots of problems which we expected but it also talks about a 'bulge and parts of brickwork needing rebuilding as follows..... i wonder if anybody could explain in simple terms what this all means ? i am going to get quotes from a builer also thanks in advance.............
'The front bay windows are twisted out of alignment at both ground floor and first
floor levels. There is a slight convex bulge at rear first floor level to the main gable.
There is a slight bulge to the base of the apex on the rear outrigger elevation.
There is cracking to the side outrigger rendering below the bathroom window. The
roof void inspection revealed poor brickwork internally (which might explain extent
of the external rendering) and in the circumstances we recommend that all the
affected areas should be rebuilt, and where necessary rendering is repaired. This
will be a costly exercise involving scaffolding and we strongly advise obtaining
estimates from a building contractor prior to exchange of contracts.
We also draw your attention to the condition of the external rendering. Cracking
was noted around the main kitchen window reveal under the bathroom window
and affect areas will require to be cut out and re-rendered
