Mike, I imagine that most other people are getting as confused as me.I know it is 2.5mm as i have bought it new. As for the 3mm cable it is slightly bigger than the 2.5mm and when measured the cross diameter is 3mm.
Cable sizes are specified by cross-sectional area of the main copper conductors, the ('Twin & Earth') type most commonly used for wiring domestic sockets having two main insulated conductors of 2.5mm² (area of copper conductor), plus a smaller bare 'earth' conductor. The diameter of a 2.5mm² copper conductor is about 1.78mm; a copper conductor of 3mm diameter would have a cross-sectional area of just over 7mm² - far larger than would be used for wiring normal sockets in a domestic situation.
What are you measuring? Does the 3mm diameter you measured perhaps refer to the diameter of one of the insulated conductors including the insulation?
One thing no-one seems to have asked you is how you plan to join the cables.I Will the 2.5mm be ok joined with the 3mm
Kind Regards, John.
