I AM NOT AN ELECTRICIAN SO PLEASE EXCUSE IF I GET SOME TERMS WRONG.
PLEASE ALSO NOTE THAT MY CONSUMER UNIT IS FULL AND THE COST OF REPLACING CU JUST TO RUN ANOTHER CIRCUIT OUTSIDE IS NOT AN OPTION. THE CONSUMER UNIT HAS AN OPENING IN A FALSE WALL TO ACCESS TRIP SWITCHES AND READ THE METER BUT TAKING OUT THE FALSE WALL AND REDECORATING ETC. WOULD MAKE IT TOO COSTLY.
I need to extend the power in one small shed to a birdhouse, which is some 20/25 metres away. Because the original fitting was done by a qualified electrician I presume it is a genuine job. Albeit it looks as though he took a spur from an existing ring circuit which has a 30amp fuse at the consumer unit.
In the shed the armoured cable is fed to a Wylex Fuse Box, which in turn has two circuits, one comprising a 5 amp fuse and the other a 15 amp fuse. The circuit with the 5 amp fuse goes to a light via a switch. The 15 amp circuit goes to a twin socket, into which is plugged a fridge. The other socket is used for plugging in a variety of garden type power tools using a plug in RCD.
My aim is to utilise this existing power and extend it to my birdhouse which is 20/25 metres away.
1. Should I dismantle the exisiting fuse box in the shed and replace it with a twin socket RCD power breaker from which I can run the fridge and light from the sockets?
2. Can I extend the armoured cable and run it to my additional shed/birdhouse and utilise the existing Wylex Fuse Box in that shed to build a lighting and power circuit?
3. If I can do the jobs in 1&2 is there a problem if I run the armoured cable , say 12 inches above ground, and tag it to a row of trees I have surrounding my garden or can I do the same using the garden fence? If I can avoid it I do not want to have to dig a an 18" trench to the birdhouse.
4. In the birdhouse I will be using a series of lights which I want to time to come on and off individually - my idea would be to put a series of twin sockets with plugged in timers and run an individual line to each light. Anyone any better ideas?
5. I would need only one twin socket power point socket so I could use a 120watt ceramic heater with a timer whenever the temperature fell to unacceptable level. I would also like to use an occasional vacuum cleaner but if this was a problem it is not essential.
Any advice would be most welcome.
