Extending Upstairs Ring Final
3 Sep 2006
Kent
I extended the Ring Final in my bedroom to add 3 more double sockets.
I did this by, at the current double socket by the bedroom door, I put an unswitched FCU next to it, & connected one of the two T+E cables from the current double socket to the supply side of the FCU, & the other T+E cable to the double socket.
I then put up some 25 by 16mm Mini-Trunking around to where the new double sockets were going, & also fixed up the surface boxes for the new sockets.
I then connected a new piece of 2.5mm T+E to the current double socket by the door, & put it in the mini-trunking around to where the first two new double sockets were going.
I then connected a other new piece of 2.5mm T+E to the supply side of the FCU, & put it in the mini-trunking around to where the 2nd new double socket was going.
I then at the 1st new socket striped the cables and connected them to the new double socket, I then did the the same at the 2nd new socket, but had three T+E's as the 3rd new socket I spured off from the 2nd new sockets. At the 3rd new socket I spured it off from the 2nd new socket.
Here are the pictures of how I did it
Old double socket by door + New FCU:
http://i167.photobucket.com/albums/u125/mdbalson/P1050014.jpg
The two white T+E's are the old cables & the two grey T+E's are the new cables.
Close up of wiring in old double socket by door + New FCU:
http://i167.photobucket.com/albums/u125/mdbalson/P1050012.jpg
The Unswitched FCU will be to supply the pump for the shower in the shower room, which is below my bedroom.
1st new socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1120033.jpg
Wires for 1st new socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1010006-1.jpg
Close up of wires for 1st new socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1010007.jpg
Mini-Trunking to 2nd new socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1010010.jpg
2nd new socket & 3rd new socket (spur):
http://i167.photobucket.com/albums/u125/mdbalson/PC140160.jpg
Close up of wires in the 2nd new socket & 3rd new socket (spur):
http://i167.photobucket.com/albums/u125/mdbalson/P1010009.jpg
Also at the back of the bedroom I have added a spur socket, by using a piece of 2.5mm T+E run in 16 by 16mm Mini-Trunking, to run from the old socket to the spur socket.
So now there are six double sockets in the bedroom, whereas there was only two double sockets in the bedroom before.
Here are the pictures of the spur socket I added at the back of the bedroom.
Current socket which feds the spur socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1120016.jpg
The Mini-Trunking which feds the spur socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1120021.jpg
The new spur socket:
http://i167.photobucket.com/albums/u125/mdbalson/P1120022.jpg
Nice job for a diyer, mini trunking work leaves a bit to be desired below the socket and boxes look a bit drunk but still not bad for a diyer.
Nice job
Nick
securespark said:
What spacing factor is in that trunking?
What do you mean by that :?:
All there is is two pieces of 2.5mm T+E in the 25 by 16mm Mini-Trunking, & one piece of 2.5mm T+E in the 16 by 16mm Mini-Trunking.
Space factor:
The ratio (%) of the sum of the overall area of cables (inc insulation & sheath) to the internal csa of the cable enclosure they are installed in.
For trunking the space factor should not exceed 45%.
wiring looks fine, trunking is a little messy but its hard to avoid that when taking a trunking feed off an existing flush accessory.
white T&E would have looked better but i think you can only get it in lsf sheath now which makes it a bit more expensive.
according to the table on that site the spacing factor also seems fine
All looks a bit messy to me, couldnt you have moved the original socket with the pipes below it and put the original cables in trunking? And why install the two side by side doubles with one being a spur, you could have easily have made them both ring sockets, the wiring behind looks little tight too so if you have to change one of the sockets because of a fault if the terminals are in a different location then your stuffed.
Top tip for you - keep things simple. You seem to overcomplicate things immensely especially in the thread you have open about re-wiring your shed.
Sorry to have a go but thats my opinion.
All the best
Dan
All the existing Sockets upstairs are surface mounted, apart from the landing socket which is flush mounted.
dannyboi2003 said:
All looks a bit messy to me, couldn't you have moved the original socket with the pipes below it and put the original cables in trunking?
I would have like to moved the original socket & put the original cables in trunking, but I couldn't because the original cables come up through the floor about 5cm or so away from the skirting board, & at the bottom of the original socket is a hole in the wall through which two 2.5mm T+Es go to supply the socket, FCU (For 2 TV sockets up by ceiling, 1 in Main bedroom & 1 in My Bedroom) & Spur socket in the main bedroom. Also the bookcase in my bedroom just about fits on the wall which the original socket is on.
What is overcomplicated about how I am going to rewire the shed :?:
just out of curiosity, what is behind the blank plate above the 2 new sockets?
also, spuring the third socket off the second is not good practice when you could easily replace one leg and make it a ring..
