Exterior door missing outer handle - how to insulate?
13 Oct 2013
Hi All,
I'm renting and one of the exterior doors is missing the outer handle from a previous break-in attempt. Because of the door design it is impossible to substitute a new handle and the factory no longer produces this type.
The door is secured with two other locks, I'm just wondering how to insulate the outside of the door for noise and draughts without ruining the lock? The door still locks and opens from the inside. I have considered silicon and foam but both would probably ruin the lock.
Any suggestions?
have you though about another handle and lock plate
either new screw holes as people will grab to shut or loads off silicon if no one will grab it :D
Unfortunately the door is a sliding door with a 3 point locking system, they also don't make the doors any more so it's pretty much not an option
Thank you for the input but that's not really helpful, the landlord hired a handyman who did the investigation into the factory and door as well as fixing up some other issues. He installed the two extra security locks but it is only now, coming into the winter, that I notice the draught and noise. I'm looking for a quick-fix I can do myself that won't ruin the workings of the lock. Hell I'd stick blu-tack in there if I thought it would do any good :D
A photograph would be useful.
You could put a door fingerplate over the hole.
