    Dismiss Notice
Exterior gas pipe price?!
Discussion in 'Plumbing and Central Heating' started by Dylan T, 20 Nov 2020.
  1. Dylan T
    Dylan T
    11 Feb 2017
    102
    Thanks Received:
    Country:
    Hi all - I've had a plumber over who I needed to move a gas pipe for me due to a relocated gas meter. The gas pipe needs to be run outside alone the perimeter of the house for about 7 meters very low and then i'll eventually tile up and over it. Due to potential corrosion he said he'd need to get special coated copper pipe and has come back saying a min of 20m is available and it's £250 just for the pipe. Does that sound right - it sounds a hell of a lot - and can you not just wrap it or use plastic? I see many places sell wrapping tape so I was just hoping someone could help! Thanks
  2. Sponsored Links
  3. denso13
    denso13
    22 Jan 2007
    4,733
    Thanks Received:
    1,043
    Country:
    If it surface mounted and visible then normal copper is ok.
    Make sure any duct is ventilated.
  4. Dylan T
    Dylan T
    11 Feb 2017
    102
    Thanks Received:
    Country:
    Thanks so even if its just in sand (no concrete) it needs to be coated?
  5. muggles
    muggles
    28 Oct 2005
    12,865
    Thanks Received:
    2,880
    Daventry
    Country:
    Yes, if it's buried it needs to be coated
    • Like Like x 1
  6. Sponsored Links
  7. Mr.B
    Mr.B
    5 Oct 2019
    181
    Thanks Received:
    34
    Country:
    I wonder if Tracpipe would be any good, (it can certainly be buried according to their websites) ... or maybe even that's what the installer was referring to - but, of course, Tracpipe comes in 5, 10 and 15 metre kits as well as longer roll lengths.
    I ran a length through my loft and it was easy to handle - and no joins. A Gas safe fella connected it.
    • Thanks Thanks x 1
  8. durhamplumber
    durhamplumber
    23 May 2010
    14,280
    Thanks Received:
    640
    Durham
    Country:
    22mm plastic coated copper.7m about £70
    • Thanks Thanks x 1
  9. Dylan T
    Dylan T
    11 Feb 2017
    102
    Thanks Received:
    Country:
    Thanks, where have you found that?
  10. denso13
    denso13
    22 Jan 2007
    4,733
    Thanks Received:
    1,043
    Country:
    So is it actually going to be buried in sand and not "very low"? How are you going to tile up and over it if so?
Loading...
Share This Page
