legs waterproofer is used in the top coat on 3 coat work which is quite rare unless your doing ashlar work. the waterproofer in the scratch coat has 2 advantages it stops moisture entering the brickwork and it equalises out the suction for the following coat. the top coat will absorb water but will not readily pass it on to the background and will quickly dry out.
