External garage electricity wrongly connected to neighbours supply
People keep an eye on their bills, something was withheld by previous owners. Sockets lights etc get added over time.
Not everyone, sublets their garages to a load of immigrants. My own extensive, and well lit garage and workshop, consumes but a few watt hours per year.
In the context of an entire electricity bill (for the whole house+garage), I really don't think many people would notice anything relating to the (probably very little) usage of electricity in a garage - and, in any event, as I have said, if electricity usage in both garages was 'similar', then there would be little, if anything, to 'notice' in the billing.
I can't see suppliers being the least bit interested if I agreed to give my neighbour electric power, or them give me power,
If there had been such an agreement between the two neighbours, then that might possibly be correct - but there clearly could have been no such agreement, since no-one was previously aware of the issue.
In the absence of any such agreement, the supplier would be billing both customers on the basis of metering which might be incorrect (conceivably 'very incorrect'), so they might well be concerned about the possible legal consequences of that.
As long as you and your neighbour don't charge an EV, put a freezer in the garage, or use it as a workshop, the amount of power lights use it would hardly be worth worrying about.
Quite so - and, by the same token, in the situation you describe, there would be no reason why either customer would become aware of the issue (unless/until someone working for one of them attempted to isolate the supply to one garage).
It’s almost inconceivable that this wasn’t known about either by the developers or spotted by subsequent owners
The developers might well have known, but responded 'so what'. How would the subsequent owners find out - the power would work, the light would work, why would they bother to investigate?
I have looked at these
I decided better to hard-wire the shed, but the move away from lead acid means leaving part charged no longer matters, and one of them would likely power my shed for a year, before it needs re-charging, and they do have the option to charge off solar panels. They also have other uses, like at the BBQ or going camping.
My one, mains powered, garden tool is the leaf blower, also works well with snow, and it is 3 kW, and for that power the portable battery is getting on the heavy side, and expensive. And my camping days are over. But looking at my neighbour, their garages are on a shared parking area,
top centre, and I can see how if the wrong supply went to each garage it would be a problem, house on right could easily put in a new supply, but house on left it would be a problem, as only cable route would be though the next doors front garden.
We all get on together so it would soon get sorted, if we had a problem, but I can see how if neighbours did not get on, it could be a problem. We have seen a plan from @SUNRAY but it does not show how easy or hard to move supplies. And once one party finds a way around the problem with for example the battery pack shown, then they will not want to pay out again for a second way around the problem.
How would they have known? Even the electricians who did it presumably did not know that they had made the error (otherwise would have corrected it) so how can the developers have known (particularly given that both garages had functioing electriocity)?
Quite so - until (as seemingly happened in the case which started this thread) someone attempted to isolate the supply to one garage (in order to 'work on'the garage electrics) and discovered (the 'proper way' or the 'painful' way!) that what they had done had not actually isolated the garage supply!
How could they manage to test the new installation, without noticing the error? Which means they either didn't bother testing, or chose to ignore the error.
The situation in my case has been RCD tripping, it's a fairly standard 5+5 2 RCD board and each time it tripped it reset okay, until the other day when it was raining, snowing etc.
Near me so I was called to see If I could localise and isolate the circuit.
N-E has over 1V so some potential for tripping, It didn't take long to find a very low resistance between N&E on the garage circuit and heading out to the garage somewhat surprised to find it powered, contact with the immediate neighbour soon established the mix-up (and for that matter isolated the wet light fitting).
They seem to be friends so not too concerned about the timescale to correct this, I made a comment about swapping garages and did they have the right ones so paperwork was extracted and inspected while I did final tests in the CU and closed up. The sequence I've shown is based on the house and garage original builders plot numbers which shows on the deeds, I didn't check the sequences either side.
Apparently further along the row there had been a mix-up with which garage was being used when a house sold and buyer found his garage keys didn't fit but I don't know about the power side of it.
