I want to extend a socket ring circuit which is on the usual 30 amp fuse. Can someone tell me please how many double sockets can I have in total in this one ring.
Remember to keep them in the ring circuit, and not to keep connecting spur -spur - spur etc .
Also the total loading on the circuit should not exceed the current rating of your rcd, fuse or MCB.. Normally 32 amp
OSG quotes 90m for a 30A fused ring using 2.5mm cables with 1.5mm earth conductor (modern cable). Actual length may depend on exact materials/breakers etc etc.
