this exactly what the manufacturers said.....
"I am sorry to have to inform you, that the HC115 shower kit cannot be used with any other components. It has been made to be used with the 3m of flexi duct pulled taught and with no additional bends or alternative components. If you add bends to this product it will no longer meet the 15l/s air flow rate as required by The Building Regulations: Part F.
I suggest you purchase a different product to meet your installation requirements. If you purchase a centrifugal fan, such as a SF90 or RF90, these product have better pressure handling and can be ducted using flat ducting."
They go on to say......
"Both the fans I specified for you are suitable for wall and ceiling installations.
The HC115 has not been tested with other components, and so we cannot guarantee the performance.
The Ducting supplied with the HC115 is 125mm the fan motor and 90degree bend is 115mm. I do not know of any 115mm ducting suppliers, and again suggest you change to a centrifugal fan which will ensure you reach the performance you need.
I have tried to find pipe fittings to fit the 115mm but no luck so I have decided to give up and send the HC115 back and purchase another, but no idea what yet. I'll let you know..... Any ideas? What a bloody saga. Simple job?.....
![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
