Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I would like to install a 100mm PIR operated extractor fan in my toilet (toilet only no sink or anything else). Can I connect the fan to the feed for the toilet light or will I need to run a spur from the nearest ring?
yes you can ,but it will also require a tripple pole isolator (even though it will ony use two poles, since as its pir operated, it has no external switch)
