F75 error Vailent boiler - no running hot water
8 Jun 2013
Gloucestershire
As per the title, no hot water at the taps. The tap runs hot but then cuts out with the F75 code.
Any thoughts on what it could be before I call the engineer out? Anything a lay-person can try? I tried switching off and on again but no difference.
It had a new fan and PCB in 2021 and the boiler itself was new in 2014
Ahh google - maybe doesn’t hold all the answers and isn’t The Oracle. F75 usually relates to a faulty pump or pressure sensor. Not a diy job as opening the cover forms part of the room seal/combustion circuit. Have you tried resetting the boiler? Try adding a little water, can just get it to limp along if not the pump until your engineer sorts it out.
Get the boiler serviced for a start
May be just me, never replaced a fan as well as a PCB at the same time. Have same boiler
It's in a rental. I think the plumber wasn't sure at the time so did both just in case and to save a revisit and a further delay.
