Fan heater stopped working - should I try and repair?
OM2
18 Jan 2007
We've got a cheap fan heater.
It's blowing cold air.
Should I open up and try and repair?
Or is it a no go area?
We've already got a replacement.
It cost less than £15.
Just wondering.
Check the overheat cutout button, fuse, plug and socket first. For the next step you will need a multimeter. If it needs a new thermostat or switch, where will you buy one to fit?
Go and buy a new one while you think about it.
It's unlikely to be a loose wire inside the fan heater, so if it's any of the components [fan, thermostat, element, switch] then they would probably cost you £15 even if you could get hold of them.
The one shot is if it has a thermal trip somewhere that can be manually reset. The instructions should tell you if that is the case. Otherwise, take it to a recycling centre
I will follow your wise words
New one purchased already anyway
I saw a youtube video
The guy was saying the fuse might be gone (as suggested)
That part looked super simple I guess
Fuse, plug and socket are OK as the fan is going.
if it has diffrent heat settings as in half and full make sure you try both /all positions same with any thermostatic heat level setting
