T
timmyquick
Does any one know where a timed overrun fan can be bought which does not require a 3 amp fuse to make wiring simpler. I have checked the wiring on my sisters house which has a timed fan working through the pull cord switch in the bathroom as does my mums ( which just passed electrical inspection from council) but neither have been fused down to 3 amp. Yet every fan i have seen say they need to be connected to a FCU at 3 amp which is impractical. Or is it allowed within the regs to fuse the feed to the ceiling rose as well thus the light being on a 3 amp fuse as well. I need to get this done right as when the building inspector sees this working he will issue completion certificate. But if i don't get this done by tuesday he says that he is going to do me for all electrics and plumbing after new year.
What method do electricians normally use when in this situation?
There must be an acceptable method as how do new build homes go on?
Forgot to mention on the house which just passed inspection there is no fan isolation yet it passed inspection?
