I have a 7 year old Worcester Bosch Greenstar Heatslave 18/25 oil combi boiler. I have a reoccurring problem every few days with the flow switch sticking in the open position and causing the boiler run in HW mode and eventually cut out on the overheat thermostat. The water at the taps is then scalding hot from the internal storage tank.
I know this has been posted before a few years ago by others, but I have had 4 new flow switches and still no solution. I’m hoping someone else has…? Any help much appreciated!
I have a magnetic scale filter on the cold water inlet although it is a soft water area. I have eliminated any leaks on the HW pipework and also tried fitting a check valve on the HW outlet on the advice of the service engineer.
