Ish said:i bought a mitre square and used it to make lines on skirting.
after cutting all the skirting i realised the mitre is slightly out so the cuts are not exactly straight
can i ask the shop to pay for the skirting???
ish said:i bought a mitre square and used it to make lines on skirting.
My next door neighbour has bought a mitre saw like the 1st picture in shaggy post and said the same as you, not cutting perfect. I said I couldn't find anything wrong with itIsh said:after cutting all the skirting i realised the mitre is slightly out so the cuts are not exactly straight![]()
nstreet said:Ish,
Am I right in reading that you are marking the line with one of these http://www.diytools.co.uk/diy/Main/Product.asp?iProductID=21742 and then using a saw to cut to this line?
shaggy said:Ish, this is the reality; quality costs.
If you are using one of these(and I've used one):
You should be using one of these(and I've got one similar but the dw712):
Ishwell said:went and got the mitre replaced today. with the new mitre my cuts are bang on straight
after i made up some noise about my skirting being scrap because of their product they gave me a £10 voucher/credit slip thing as well
GRC said:Ishwell said:went and got the mitre replaced today. with the new mitre my cuts are bang on straight
GRC - Victory for The Consumer. Did the £10 cover all or most of the cost of the skirting?
Regards, Graham
____________________________
moderator
edited to corrrect quote
