Hi, we had a new kitchen installed a few years ago and the electrician converted a double socket to a standard plug socket on one side and an FCU on the other. I had reason to inspect this today and the set up is that the mains wiring goes into the plug side and additional live and neutral are run to the FCU side. But no earth has been run to the terminal on the FCU. Is this correct? If it is, I'm guessing that one earth is sufficient for both as they are both in a double metal socket box. But I thought I better check.
Thanks in advance for your help and advice!
