featheredge fence - nails or screws
30 Mar 2015
Hi All,
installing a featheredge on top of a brick wall. Will install a 3x2 frame for the featherdge to be fixed to.
should I use nails or screws and what size/spec please?
would really appreciate a quick response as I need to get to it.
thanks in advance
Galvanized wire nails 2inch long . Don't use bare steel nails - the rust runs down the wood
Thanks for your help @Nige F. Thought I would share my progress.
Nice fence work, is the top rail a flat piece of timber? As water will sit on top and rot the timber away.
Andy
yes. Need to put calling rail on. I thought I would measure the width once the featheredge is up.
On the capping guys, I've had to have this custom made due to the width. This means that the timber is no longer treated. How should I treat this? I am eventually going to use a fence and shed type treatment to give everything the correct colour but wasn't sure if anything else should be applied first.
Also, am I okay to nail this on too or should I use screws and finally, how much space should I leave at the end to allow for expansion?
Thanks in advance.
