The boiler spec asks for a proper protected outside electric supply. I take it the house ring will suffice with a cct breaker socket and plug. Will it be OK to make use of an existing socket and run a cable through the wall to the boiler or does the isolation switch need to be outside. Note the boiler has its own power switch on the front panel. Thanks.
