My neighbours and I have a low wall between our driveways that offers no privacy and is fairly dangerous from the higher side. We'd like to add a fence to it, maybe around 5ft high. I'm not sure how best to go about it.
At first I thought about removing sections of the coping stones and using bolt-down post supports attached to the wall but realised that was likely to simply lever a few bricks out of the wall. I then wondered about removing a pocket of 3 or 4 courses and creating a concrete pad where each post wsas needed. Would that be nearly as likely to fail?
Although it would be nice to have the posts on top of the wall, I realise that another option would be to fix posts onto the side of the wall (the near side in the photos as there's more height to work with) and notching a bit of the coping stones. My gut feeling is that that would be more durable if fixed (screwed?) near the top and the bottom of the wall - what do you think?
Any other ideas would be welcome, and/or tips on how to proceed if you think one of the above will work (eg fixings). Because the wall height changes and the degree of privacy wanted changes I think it's probably going to work best if I use rails and feather edge boards between the posts so I guess I'm looking at wooden posts.
Thanks, Phil
Thanks, Phil
