I'm replacing the damaged panels in my back garden with closed board fencing ( assemble it yourself stuff slotted into the grooves on the concrete posts ) as and when they break.. ( won't be long, they're all pretty much had it.. )
one problem I've come across is that there is an apple tree on her side that is growing against one of the concrete posts and pushing it over..
since I'm replacing with closed board then there's the opportunity to move the concrete post either way and avoid the tree.
now, the problem is that I'm using a 3rd rail at the bottom of each "panel" I replace that is resting on the concrete gravel board.
If I move the post in one direction then the concrete gravel board is too long and needs cutting, if I move it the other then it's too short and won't sit in the groves of the posts.
do they make longer or shorter concrete gravel boards? how easy would it be to cut one? ( I can borrow a 9 inch grinder and disk if needs be.. )
then there's the future problem of what happens later if the next owner decides to put regular panels back in.. they'll either have to cut a panel or try and find a wider one ( by about a foot. )
