Festive/Christmas Lighting
Third time lucky? ....
Kind Regards, John
The fuse bulb is relatively recent. They certainly didn't have them when I were a lad. They didn't have bulbs that went short circuit on failure either. It was my job to sit under the tree with a battery testing each lamp in turn.
I don't know when you were a lad, but many of those bulbs I just illustrated are at least 30 years old. I know that since most of them originated from sets I bought a fair while before I moved into my current house, a bit over 30 years ago.
There were, as you say, some sets of lights in the past whose bulbs did not go short-circuit on failure, but they obviously did not have (or need) a fuse bulb, since each bulb acted as a fuse.
Kind Regards, John
However, in a 240 V series string a 12 V lamp cannot be considered to be operating on ELV.
Well - if it is a 12V lamp and it has 12V across it I don't see how it can be considered to be operating on anything other than 12V.
Surely the whole set-up must be considered and that is operating on 240 V, which is LV.
The item as a whole is not ELV, in the same way that a 12V downlighter is not ELV if you include its power supply.
I too was under the impression that they are a relatively new "invention". Though I suppose there's a bit of "cheap lamps didn't need a fuse bulb, so they weren't used" - and it's only relatively recently that consumer pressure forced manufacturers down the short-circuiting bulbs and fuse bulb route.
And I also remember the annual ritual of getting the lights out and getting them working :evil:
We had almost no failures in our tree lights because we didn't run them at full voltage. Must be something like 30-40 years ago I remember dad had a couple of industrial panel indicators wired in series, later swapped with an auto-transformer in a box with several sockets on the top for the light sets.
As to aesthetics, I find many (well most) LED sets "unpleasant" compared with the old incandescent fairy lights. In parts that's because so many of them have such tiny pin-pricks of very bright light. We had to shop for new lights this year, and found some sets with "berry" sized LEDs which seem OK - SWMBO is happy with them ;) We did see a few sets of incandescent lights on sale, but I'd say it must be something in excess of 90% LED now.
When I wanted to get some spare lamps for my tree lights, about 14 months ago (mirabile dictu I for once did something in a timely fashion) I found I could only get them online. And that a whole single-string 40-lamp set cost very little more than a pack of 10 lamps.
