Given that part of the process of designing a smoke/fire alarm system SHOULD include an assessment of the acoustics, there really is no logic in demanding that a device be installed in the most frequently used room just as a linked sounder. Without one in that room, at least one other sounder will be clearly audible - if not, then the system was not designed properly. It would make more sense to require that the system be designed to some standard or other which covers such matters.
I find the mention of sprinklers interesting - but also alarming (no pun intended). I don't think I've ever seen these in normal domestic premises, and retrofitting them would not be a trivial job in most properties, and impractical in many. It may be a case of "send three and fourpence, we're going to a dance" - where someone has heard a suggestion that certain types of buildings needing them in certain areas (communal hallways & stairs of high rise flats/apartments being a prime example), and somewhere along the line, the details have been lost and so people are led to believe that it will apply to regular houses and low rise flats.
As an anecdote, an architect acquaintance told me years ago that she was doing some work for a well known supermarket chain - and queried the lack of sprinklers. The policy from the supermarket was not to fit them as "false alarms" regularly caused significant costs in damaged stock and fixtures - which is a valid concern, spraying a load of water around does cause a lot of damage. Shortly afterwards, the supermarket suffered two fires in different stores within a couple of weeks of each other - causing total loss of the buildings which were reduced to twisted piles of heat-softened steel. There was then a program of retrofitting sprinklers to all their stores as they'd obviously re-assessed the relatives risks of the to have/to not have questions.
I know where I worked, they had sprinklers right through the site - offices, factory, and warehouse. Fortunately we didn't have any false alarms - but apparently it can be a real problem with events like forklifts (or their loads) breaking a head. Some systems are dry - needing a separate fire alarm to release water into the system - but most are wet and the water is only held in by a liquid filled glass phial keeping a plug in each sprinkler head, when things get hot, the internal pressure breaks the glass, the plug pops out and water flows.
