fire fitting
18 Feb 2006
Birmingham
Ive removed out old fireplace and fire which had a back boiler behind as well, so now the hole is quite wide.
What size should this be to allow for a normal fireto fit in and also where should I pipe the unconnected gas pipe to, to allow corgi regiatered to test and connect? The previous pipe was on show
You shouldn't do anything with the gas pipe - that's for Registered Gas Installers only.
I think you should have involved your CORGI by now as you have more than likely overstepped the mark
