Fire-rated downlights in extension? Electrician right?
The TTL tests In 1996, the DoE and TRADA commissioned TRADA Technology Limited (TTL), a member of the TTL Chiltern group of companies, to test the effect of recessed downlighters (with no boxing in or fire hoods) on the fire resistance of plasterboard ceilings with conventional rectangular joists. TTL has been involved in fire research and testing for many years and is the UK’s leading authority on the fire protection of timber. During 1994/95, TTL carried out the tests. The results of the tests were published in the July 1996 edition of Building Control magazine. These results were, perhaps, surprising in that they confirmed that downlighters, even without being boxed in and with no fire hoods, in plasterboard ceilings have little significant effect on fire resistance ratings up to 30 minutes. It must be inferred from these tests therefore, that, at least with plasterboard ceilings with conventional rectangular joists, it is not necessary to ‘box in’ luminaries or to use fire hoods for the purpose of restoring the fire resistance capability of ceilings which are not of fire compartment construction.
You can get fire rated tilt recessed lights - such as here
http://www.tlc-direct.co.uk/Products/FRSG10W.html
You'll be better off for it as otherwise all sorts of dirt/dead insects end up in the lights
But I'm not worried about dead insects, and I intend to fit LEDs into the fittings. And so many advertisers don't even tell you the tilt angle their product offers.
So many electricians misunderstand this topic and seemingly through misselling these are being pushed on me. If there was a safety case backed up by the regulations or research I would be happy to give in.
I would rather save the extra money and buy more smoke and heat alarms. Far more effective.
I have asked the electrician to show me where it says we need fire rated fittings in the regulations but I don't suppose he will.
not sure I get the reply - but perhaps you are thinking that the tilt won't enable you to retrofit LED lamps as they are larger than normal lamps? You can get good LED's now that are the same size.
Also dirt and dead insects collecting around the base of a lamp do present a possible fire hazard.... and even LED's build up heat.
I think it would be cheaper to pay the extra few quid for a fire rated fitting than to buy smoke/heat alarms and get them installed
It seems to be a common misconception that "fire-rated" (or whatever you want to call them) lights must have some kind of IP rating which automatically makes them OK to use in bathrooms, will stop insects getting in and dying etc.
This is not necessarily the case - their job is to block the passage of fire and fire products by closing paths through the light by having components which expand when they reach temperatures of several '00° C. In normal conditions there's no guarantee that the light will stop anything passing through it or getting into it.
