Hi chaps,
Not sure if this should be in this section or building but...
I am preping our fireplace so accept a class 1 inset gas fire, obviously I am doing none of the gas work myself. I have had a chimney sweep in to do his thing and he gave me some advice on prepping but want second opinions as I obviously want to do everything within safety bounds.
As you can see from the images below, the fire is far smaller than the opening. The sweep suggested sheet steel to funnel into the chimney opening, as you can see it is very square currently. Is this the best material to use? Or would it be better to use something like plaster/concrete board with a skim of plaster over the top? I am going to have to close up the sides and back fill behind somewhat as well, best materials for this? Fire cement and brick?
Thanks in advance!
Ste
Thanks in advance!
Ste
