    Dismiss Notice
fitting a chimney liner
Discussion in 'Plumbing and Central Heating' started by jersey, 22 Jun 2009.
  1. jersey
    jersey
    29 Jan 2008
    61
    Thanks Received:
    Derby
    Country:
    going to fit a chimney liner myself have total confidence in doing it but just wondered if there are any tips to be shared the only thing im not 100% on is using vermiculite to seal the gather hood (wot mixture do i need ?? ) above the fire back :idea: :idea:
  2. Sponsored Links
  3. namsag
    namsag
    12 May 2004
    9,909
    Thanks Received:
    324
    Country:
    Tie a washing line onto liner and drop the line down the chimney on a weight. As you push the liner down the chimney it will probably find a bend which may cause it to stick a little. Spin and push liner while some one is pulling on the washing line.
    Make sure you have everything covered with dust sheets and hole covered if line not being pulled on. Its amazing how much sh#te comes down.
    Also make sure you have a long enough liner as no joins allowed.
  4. Agile
    Agile
    26 Jun 2004
    63,744
    Thanks Received:
    4,549
    London
    Country:
    Do you have a gas registered engineer who can test the flue after you have fitted it?
    Tony
  5. namsag
    namsag
    12 May 2004
    9,909
    Thanks Received:
    324
    Country:
    Why?? , its not for a gas fire
  6. dextrous
    dextrous
    14 Mar 2009
    6,319
    Thanks Received:
    195
    Manchester
    Country:
    I thought metal liners weren't permitted anymore. Don't know where I got that impression from.
  7. Agile
    Agile
    26 Jun 2004
    63,744
    Thanks Received:
    4,549
    London
    Country:
    Right well if its a coal fire then obviously a gas safe engineer is not required.
    I did not think there were any areas which still allowed coal to be burnt.
    Tony
  8. namsag
    namsag
    12 May 2004
    9,909
    Thanks Received:
    324
    Country:
    I sometimes wonder what world you actually live in at times .
    Still see the occasional coalman
  9. Agile
    Agile
    26 Jun 2004
    63,744
    Thanks Received:
    4,549
    London
    Country:
    I recently advertised about 100 kg+ of premium smokeless fuel but there were no takers!
    Now I have to find somewhere to dump it unless someone on ebay will bid on it.
    A KF Mk II CF80 I disconnected yesterday is being listed on ebay at 99p as the owner thinks its better to recycle than scrap.
    Tony
  10. Sponsored Links
  11. LeeC
    LeeC
    19 Feb 2006
    29,389
    Thanks Received:
    8,868
    Country:
    My mum still has her lovely TRG45 running anthrasite, she'll never change as coals free cos the old man (god rest) used to be a miner,gas bills £5 a quarter.
  12. Agile
    Agile
    26 Jun 2004
    63,744
    Thanks Received:
    4,549
    London
    Country:
    More likely to be burning anthracite!
    Thats probably imported from China now!
    Tony
  13. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    We'll have it! We burn a mixture of smokeless and well-seasoned wood and sometimes even peat on our multifuel stove. We are stove fanatics; we love collecting wood, cutting and storing it for the winter. Nobody is bothered about smokeless regs any more, the few like us who do burn real fuel are considered eccentric. Wood burns better if you start the evening with a bed of coals in the grate.
    The only problem would be getting your coal up to Lancashire. I'd seriously consider sending a carrier to collect it - is it bagged? Do you know the exact weight?
  14. Agile
    Agile
    26 Jun 2004
    63,744
    Thanks Received:
    4,549
    London
    Country:
    Its in thin bags at the moment in the back of an estate car.
    I will see if I can transfer it into propper rubble bags and try to weigh it next weekend.
    It seems such a pity that after its been mined and manufactured to throw it away. I like to be ecofriendly.
    Tony
  15. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Drop me an email at: reedy at orchardhouse dot fsworld dot co dot uk when you know the weight. Where are you?
    It might cost more than it's worth to get it transported but like you I'd be loathe to see it dumped. We do have a van and some reps going down to The Smoke occasionally.
    (Sorry about the thread hijack, by the way!)
  16. jersey
    jersey
    29 Jan 2008
    61
    Thanks Received:
    Derby
    Country:
  17. nickso
    nickso
    30 Oct 2006
    6,719
    Thanks Received:
    301
    Country:
    you havent posted in 8 days, you must be really desperate for an answer. :rolleyes:
Loading...
Share This Page
