Fitting a Multi fuel stove into a con`y
18 Aug 2010
Manchester
Hi all, a while ago i built ourselves a con`y, now we have been using a calor fire, not the best i know, but we have got a multi fuel stove to fit in there.
Now i built the con`y as a separate unit from the house ( left in the external grade french doors from the house into the con`y)
Now as it was built without building regs then if i fit the stove does the fitting of the stove still need to be with in building regs?
The first choice of where to fit the stove will be along the front wall on the dwarf wall next to the door and flue throught he wall then up to 300mm above the gutter.
thanks all
wayne :D
