I hope to replace an old Myson Compact CP53 water pump, with a new one (just bought it). Usual old central heating system, primatic cylinder, gas fired boiler, etc. There are 2 isolation valves, one each side of the pump. I would like help with three questions if possible:
1) how do I know if the isolation valves are the type you screw down fully to close, or just do a quarter turn. Also, there appears to be a locking nut on them that needs to be loosened, is this correct.
2) is it okay to do this rather than drain the system (which I would like to avoid if possible).
3) assuming I turn the valves off successfully, is the correct procedure to simply disconnect the wiring, undo the large nuts (I think they are 1 1/2" BSP), remove the old pump, replace the new one (wired up), screw the nuts back tight, then open the isolation valves.
Your comments would be appreciated before I flood the house and/or electricute myself.
I'm not a lover of plumbing (having had a couple of 'accidents') and I'm not over keen on electrics, but this seems a relatively simple job. Is it, or am I just foolg myself.
