Hi guys I live in the top floor flat of a converted mansion and have terrible hot water pressure. I intend fitting a pump to the system but here is the problem...
I don't have a cold water storage tank in the loft as the loft is very small and the mains water is the only source of cold water. There is an emersion heater with only one 15mm pipe (i assume is the inlet) at the top of the tank and one 22mm pipe coming out mid way (i assume this is the hot outlet.) now the pump I have is a Briston 2bar duraspeed. As I am aware I cannot pump mains water so what do I need to do as the is no cold feed anywhere near the emersion tank.
