I'm looking to install a new outside socket for use with garden power tools.
There's a single power point behind our washing machine. It's just below the worktop, about 750mm above the floor and on the inner face of an external cavity wall, and I want to use this socket to provide the outdoor supply.
The washing machine is plugged into this power point, and the socket is supplied via an isolation switch on the wall above the same worktop; the type which is illuminated when on. We switch it on when the washing machine is in use, and off when it isn't.
Am I correct in believing that there would be no extra protection to be gained by fitting an RCD protected socket on a main which is already RCD protected?
Given that the socket which will supply the outdoor power point is already isolated, would I need to fit an additional isolation switch on the inside wall for the outdoor socket?
Is it OK to use ordinary PVC sheathed cable as long as it isn't exposed to the weather?
Thanks in advance.
Thanks in advance.
