Fitting Architrave over newly plastered walls
13 Feb 2007
Dear all
I recently removed all the architrave and skirting from the doors in my house and have had the walls plastererd.
Now the plaster is higher than the actual wooden door frame so that when I put the architrave back on it is not flush with the door frame and wall and there is an unsighly gap. Whislt I can nail the architrave on and fill the gap where the other side of the architrave meets the wall the gap is not even all round the frame so that when I join all three bits of architrave together I do not get a neat finish.......
I was wondering if there were any tips out there that I could use to get the walls back flush with the door frame so that my architrave sits on flush with minimum filling?? (i.e. do I need to sand the plaster back to the door frame?).
we normally secure a thin plant to the casing prior to applying the plaster. :rolleyes:
the flatter you can get the architrave to sit the tighter your mitres will be.
Hello
Apologies for resurrected this old thread. I have a similar problem regarding a couple of walls we've had skimmed. In a few places the plaster is proud of the door lining.
What would people recommend? Removing the excess plaster to bring the level back to the door lining or chamfer the back of the architrave to fit the profile of the wall.
Thanks...
If you can scribe the architrave to the plaster that will prevent you causing surrounding plaster to fall away but if it's only a few localised snots and the plaster is still fairly fresh you may be able to scrape it flush with a wood chisel or scraper
