Hi all.
I'm using one of those cistern replacement kits, where you take out the old float valve and all the rest of it, and put in new components. But the problem is I had to undo all the other fittings that joined the cistern - like the old overflow, and the existing water supply pipe.
Now I'm doing them up again, of course they are leaking - and that's before I've even turned the water on again. The overflow is plastic fittings which tighten around the base of the cistern, and the supply pipe is a metal nut which screws onto the new plastic fitting.
What are my options for sealing these please? Sorry if this is obvious to you but I am new to plumbing and appreciate any good advice!
