I'm new here and have a question about a cooker that needs fitting. I want to know if it can be put on the kitchen ring, or requires a dedicated cable from the consumer unit.
The cooker has the following specs: Main oven 2.3KW, Small oven 1.3KW, Grill 2.6KW. The hob is gas, so no extra there. You can't use the grill at the same time as the small oven, so the max from the cooker would be 4.9KW.
We also have a washing machine and kettle that could be in use at the same time.
The kitchen ring uses 2.5mm cable and is protected with a 32A MCB.
Your advice would be hugely appreciated.
Thanks, Will
Thanks, Will
