    Dismiss Notice
Fitting Salamander S Flange?
Discussion in 'Plumbing and Central Heating' started by pat5627, 25 Oct 2008.
  1. pat5627
    pat5627
    27 Jan 2008
    57
    Thanks Received:
    Yorkshire
    Country:
    I'm trying to fit a Salamander S Flange to my cylinder to run a Salamander pump. The Cylinder top is a male fitting and I need to fit the 1" Female socket to the top of the cylinder,but as the thread on the cylinder does not go right down to the top of the cylinder how will it seal? I thought the fibre washer suppied would fit between the nut and the cylinder but there will be a 1/4 inch gap at the base-will it seal against the threads ,do I need to use boss white on the threads?
  2. Sponsored Links
  3. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    you sure thats male fitting doesn't come out of the cylinder and isn't part of the cylinder, then you can fit a surrey flange.
    have you a pic ?
  4. pat5627
    pat5627
    27 Jan 2008
    57
    Thanks Received:
    Yorkshire
    Country:
    No it is definately part of the cylinder -I can actually make out the solder lines.
  5. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    you sure its not be soldered in after as the flange should screw right down to the fibre washer.
  6. pat5627
    pat5627
    27 Jan 2008
    57
    Thanks Received:
    Yorkshire
    Country:
    I've had someone in who's also confirmed its part of the tank. the house is only 15years old and there appears to be quite a few quirks
  7. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    can you get us a pic ?
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
