fitting upvc door in timber frame extension
3 Mar 2008
Gwynedd
HI
Where exactly in the aperture of cavity walls do door frames sit? Do they span the ( 50mm) cavity or sit entirely in the ( 120mm ) timber frame. I am assuming they don't attach to the block work outer leaf?
The back of the frame sits to the inside of the outside block work a cavity closer then spans the cavity
so that means the frame screws into the block work and the plaster finish covers the timber frame and closer?
Thanks to you both for explaining that detail.
I am happy to get on with it now!
