I've replaced several window sills successfully with hardwood, fixing it to rendering and brick that was left when old quarry tile sills were removed.
This time the window sill is in a newish extension so I'm fixing to a plastered surface.
The hardwood window sill is bowed in the middle. The joiner said that this was 'normal' because it is only 20ml thick. Over a length of 1850mm it bows up by 25ml in the middle. I can get it down flat if I use all my strength.
He told me to use High Grip and that would hold it flat. But even if I glue it and sit on it till the glue's dry, won't the spring in the wood just rip the plaster off?
Any suggestions to straighten the wood out?
Thanks for reading, hope you can help.
Min
Min
