Fixing handrail to newel post
m0t
23 Oct 2006
I've just had a wall moved upstairs and this has created a landing that I need to put a balustrade on.
I've bought everything I thought I needed but am stumped with fixing the handrail to one of the newel posts.
I ordered fixing bolts which have a square that you screw into a recess on the handrail and then bolt through from the other side of the newel.
One of my posts will have two handrails to form an L shape. I had thought that I would be able to put the bolts at slightly different heights to avoid them hitting in the middle of the post but the handrail is only big enough to fit the square nut thing in one place.
Is there another option for fixing handrails in this scenario so they are on the same level?
Could you drill right through one, with the metal bracket temporarily in place so you can see where it will be, and use a dowel?
Ideally on whatever is less likely to take a load.
An alternative to a wooden dowel glued in would be a carefully aligned woodscrew - maybe 2 to avoid twisting. A lot of handrails are very flimsy until it's all locked up
  • Thanks
Reactions: m0t
Thanks both, I've ordered some Zipbolt slip fixings. They look like just the right thing for the job.
