I need to fix some heavy duty wall shelving brackets into some solid lightweight block (thermalite sort of stuff).
The best load ratings without using resin are Rawlplug FF1 frame fixings which give 0.75kn pull out load. I've just managed to get the technical details for these fixings and they suggest a minimum 100mm distance to edge. The problem is the blocks are only 200mm high anyway, which in theory means the fixings need to go into the centre of the block. Obviously not very flexible depending upon where the fixing holes of the bracket are located.
Does anyone know whether the distance to edge is likely to apply when the block forms part of a standard mortar joint wall and whether there is any flexibility to vary these requirements without compromising the block/fixing.
Any views much appreciated.
Many thanks,
Damian
Many thanks,
Damian
