I have a tiled floor that transitions to a wooden floor using a sloping tile section about 100mm (4") wide. The problem is that the bedding under the sloping tiles has broken up and the tiles have become loose.
I got some advice to just use tile adhesive instead of a concrete based bed. Is that a good idea?
What's the best way to fix this?
The transition goes from a concrete bed of around 30mm down to a metal strip about 10mm off the wooden floor.
