flame lift
15 Mar 2006
if i had flame lift on a boiler what would be causing it thanks
JEF321 said:
if i had flame life on a boiler what would be causing it thanks
Life or lift?
how long do flames live for?
Are flames actually alive? Wow im having a 'moment' here.
All sorts of things. what boiler is it......elm leblanc??
lack of air for combusion?
Is flue obstructed in anyway?
mmm injectors, blocked filter, crap on burner
when was the last time you had it serviced?
corgiman said:
mmm injectors, blocked filter, rubbish on burner
about 9 month ago could it not be the burner pressure or working pressure from meter to high
dont know worcester boilers, but is your flue going up through the attick,if so, and its a concentric type (exhaust in middle pipe, air on the outer) sound like one of the inner pipes may have slipped, letting products of combustion back down the air intake, causing vitiation of the flames (searching for oxygen)
i would be lookin at any vertical sections, but this is a job for a corgi...
Probably not relevant here but flame lift off on a newly installed boiler is almost always caused by a faulty flue seal allowing POC to leak from outlet to inlet thus starving the flame of oxygen.
Tony
