Static said:145x47 C16 @ 400c/c with a dead loading of 0.6kN/m2 can span 3.9m, as i said before thats with 0 live load. Your whole idea will be a little springy and your looking at about 6-10mm deflection in places, but thats within acceptable limits (just) and there is no live loading to create cracks.
A less flexible option would be 170x47 members @ 400 centres (also will get passed by building regs easier).
Roofer said:If you go the timber joist route it would be far better to have joist hangers in the walls rather than bearing on a batten, neater as well
Springy as in each 3.9m long member will deflect(sag) by 10mm from straight on dead load alone. Springy as in vibration may cause cracking of the plaster from say a slamming door. Go for the 170dp joists they will only deflect by 7mm, or even 195dp members with 5mm.But surely deflection should only be a issue when you apply a live load?Even if it was slightly springy, no one will have access to the void so it would matter if it was a little springy as long as it didn't sag (or whatever the structural term is for that)
Roofer said:I don't have any direct experience of either systems but IMO the metal framing would be a lot faster and cheaper
jbonding said:Roofer said:I don't have any direct experience of either systems but IMO the metal framing would be a lot faster and cheaper
i would agree its alot faster the cost may be similar but the amount of waste is a lot less. i would say if you know how to do it it would be done five times quicker or more, than doing it in timber. also its probably atleast a tenth lighter![]()
Static said:My timber size was based on 400mm centres, so your looking at 17 joists per side, 34 total.
Monsoon said:jbonding said:Roofer said:I don't have any direct experience of either systems but IMO the metal framing would be a lot faster and cheaper
Sorry I dont follow your reasoning.
Why will I create a lot of waste? Based on the above drawing I've calculated I need.
22 X 4m lengths of 145 X 47 C16 @ £1.50 per m2 = £132
1 X 6.5m Timber I Beam @ £4.00 per m = £26
36 sheets of 2.4 X 1.2 plasterboard @ 3.50ea = £126
48 joist hangers @ £20
Total £304
jbonding said:Monsoon said:jbonding said:Roofer said:I don't have any direct experience of either systems but IMO the metal framing would be a lot faster and cheaper
Total £304
where from?
Static said:http://www.jji-joists.co.uk/ software is for TJI style joists not standard timber
