- Joined
- 3 Jan 2017
- Messages
- 51
- Reaction score
- 6
- Country
Hi all,
I'm building a timber framed garden room with a flat warm roof.
my build up for the roof will be:
joists
18mm OSB3 sub-deck
vapour control layer
100mm foil backed celotex GA4100 or similar
11mm OSB3 top deck
EPDM
My questions are:
1. Do I need a VCL considering the foil on the insulation acts as one?
2. Would trying to use foil tape somehow to connect the undersides help?
3. If not, what is a good product that conforms with b regs EN... (I've seen that screwfix polythene sheets do not conform)
4. What tape and how much overlap do I need to connect together the polythene sheet (if indeed best option)?
5. When fixing the top deck aren't I going to pierce the VCL as I need to screw through the insulation and sub deck into joists below, is that an issue and is there a self sealing product that can withstand being pierced without allowing vapour through?
Any clarification would be fab. Cost is somewhat of a consideration but mainly want to make sure it's not going to have condensation in the roof. Attached is a photo of current progress. May make it clearer.
Cheers!
joists
18mm OSB3 sub-deck
11mm OSB3 top deck
EPDM
My questions are:
Cheers!
