I am looking to wire up an outside light within the next few months (PIR flood light, 400w). I was hoping to create a spur off the lighting circuit (protected by 5amp fuse) in the loft - once i calculate the amp draw of the light itself - and then run cable outside the house to the light fixing.
I'm just wondering whether 1.5mm t&e would be suitable for being used outside or should i go with flex as it's meant to be more 'durable'? T&E seems to be pretty cheap, but i don't mind extending to flex if it will be better!
Cheers.
Cheers.
