Just wondered if I should use the flexi type of fitting under the floor on heating pipes. do they stand up to the heat and pressure over time?
I know people use the pex pipes, but i don't trust them from what I've heard from people that have had failures. My thinking is that a soldered joint or compression will leak within a few days if its going to, but the speed-fit can just fail for no apparent reason.
I have actually done the job with all soldered joints, so academic really, just wondered if I could have cut corners a bit with the tight bends and cross overs etc
