I am looking at using some flexi pipe to connect a boiling water tap to its hot tank. I need the pipe to be able to withstand temperatures of 110 degrees and pressures up to 6 BAR. Is this possible?
Also. I need one of the pipes to be female (end 1) and female (end 2) what is the smallest size I can get? 10mm? 12mm? Or is there a better size I should be using?
Any help greatly appreciated.
